B Hydraulic pump
Raptor44
Just had a new shaft made for my Hyd cylinder. How do I prime my pump and cylinder to make it work. Pump is already installed. There is a fill port on the top. Thanks for any input.
Is there a way to fill the pump without draining the gearbox and putting the pump in a bucket of oil and trying to work both pistons?
Ok I am not sure if this pump worked when I started on the tractor. Fellow who gave it to me said it worked when he parked it ten years ago. I replaced the shaft and painted the cylinder today. Reinstalled and engaged the pto and started the tractor and after 20 seconds started getting oil seeping from the packing nut. Let it drip and tried engaging the pump up and down and nothing happened so I extended the shaft by hand. Now I can't push it back in. What do I need to fiddle with to get this thing working? Do I need to take the line off and push the shaft back in and then retighten the line? Or is the pump chumped up? All the controls appear to working fine at the pump. Up and down.
