TractorLinks.com
Show Parts for Model:
belt pulley for a G
leon
08-13-2017 04:50:31
I accidentally dropped my belt pulley assembly and the cast v-belt drive pulley (318524) didn't survive. I see that for an arm and a leg ($125) there's one on ebay, but would anyone here be willing to part with one more reasonabally?
Richard G.
08-15-2017 06:34:01
 Re: belt pulley for a G in reply to leon, 08-13-2017 04:50:31
Leon Check these out and just drill the holes to bolt it on and shim out with washers if needed.
https://www.mcmaster.com/#v-belt-pulleys/=18y8uzr
Richard in NW SC
Richard G.
08-15-2017 06:38:47
 Re: belt pulley for a G in reply to Richard G., 08-15-2017 06:34:01
Should have said "Quick-Disconnect (QD) Bushing-Bore V-Belt Pulleys"
Bob
08-13-2017 09:56:01
How badly is it broken? I would never suggest welding or brazing a high-speed, or heavy rotating part such as a flywheel, but a little beltpulley could probably be repaired easily and safely.
Come to think of it, IIRC, the beltpulley on my late Uncle's G was steel. Did you break the housing or the pulley?
leon
08-13-2017 12:02:51
 Re: belt pulley for a G in reply to Bob, 08-13-2017 09:56:01
It was a cast iron one that I broke. I've not seen a steel one, but wouldn't be adverse to that either. At least 5 pieces, 4 of which I have. Local hardware stores don't have anything steel that could be readily converted to work.
Bob
08-13-2017 13:23:19
 Re: belt pulley for a G in reply to leon, 08-13-2017 12:02:51
Is this a flat belt pulley or a "V" for driving a mower, etc.?
leon
08-13-2017 13:33:26
 Re: belt pulley for a G in reply to Bob, 08-13-2017 13:23:19
Oops, for got to mention that. !/2" Vee.
Bob
08-13-2017 15:39:30
 Re: belt pulley for a G in reply to leon, 08-13-2017 13:33:26
What O.D.?
Does it fir a splined shaft 1-1/8" or 1-3/8" O.D.?
BTW, 1/2" sure sounds narrow, what would that be, and "A" belt?
leon
08-13-2017 16:32:36
 Re: belt pulley for a G in reply to Bob, 08-13-2017 15:39:30
It’s for 1/2” back width V belt (A, 4L) 5” OD and centers on the 4 holes of 5/16” diameter that are on a 1 15/16" bolt circle. (No splines.) The clearance hole in the center needs to be at least 1 1/4" diameter, not necessarily square. I'll try to post a photo.
Bob
08-13-2017 17:11:47
 Re: belt pulley for a G in reply to leon, 08-13-2017 16:32:36
OUCH! I'd silver-solder or braze that if I had all the pieces!
If originality isn't important, it would be easy enough to drill 4 holes in a steel sheave blank, such as made by G&G and sold though many farm suppliers.
