Fluid in G transaxle
leon
I can't remember what I put in the G's transaxle and can't find recommended weight in any of the manuals. It has no hydraulics. I need to add after a repair job. Please help me out.
8 quarts SAE 20W.
I have just worked on two clutch housing assemblies and seemed like excessive wear on gears and bearings. These parts depend on the oil slinger for lubrication. I wonder if the oil slinger works better with thinner oil.
In both of my G's, one had a hydraulic pump, the other does not, I put "303 Hydraulic Oil".
Owners manual for AC G says: 20W is for the engine for which they normally recommend 30W (nondetergent)
90W for the transmission/differential case. But I've been using the 303 hydraulic oil from TSC, don't know if that is good or bad.
