WC Fuel Filter
I am looking for the parts list, and part numbers, for the AC gasoline fuel filters with the screw on glass bowls. I understand the screw on bowl filters were used on the WC, B, and C gasoline tractors. Any help would be greatly appreciated.
Charlie
Only ones i have even sen on the B/C/WC/WD etc where the common sediment bowl filters with a simple screen and there common as dirt and can be found in most any farm and home store or tractor dealer
That style was used on WC from serial #92330 thru #107704. Part numbers are 210182 the whole assembly; 210187 bowl; 210188 gasket; and 210189 filter. It would be simplest to just replace the unit with the newer style available at farm stores.
