hello, while my uncle had allis tractors on the farm since 68, i only ran those once in awhile a d15, and a d 17, both primarily used as chore tractors, now, i just traded a running but ugly farmall cub for a running but ugly wd, engine overhauled a couple years ago, and runs good, little leak from the rear main seal, [ is there a tractor that doesnt leak there? ], i got to fix the front end which should be relatively easy [ wide front, replace missing studs on the front mount with studs] and drain and refill all gear boxes just for pm, ] it has a home made conversion for a 3 point hitch which isnt complete, id like some pics of what you guys have made for a 3 point hitch using the original lift arms, [ no snap couplers on this tractor but the arms are there and they work, i plan to do a working tractor rebuild and use it
