WD45 rear wheels
GregoryKS
I'm putting on new 14.9-28 rears on WD45. Should I have them refill with fluid or change to 140# wheel weights? I pull a 2 row John Deere planter and a 6 foot King Cutter disc.
The fluid will weigh more than the wheel weights, but like the other poster says, for your intended use, you don"t need loaded tires. Loaded tires are intended for tillage and other heavy loads.
