D-19 carburetor
T-Dog
New User
Bought a rebuild kit for the Marvel carb on my d19. Tractor will start now, but leaks gas everywhere. I'm looking to just buy a new carb, can't find one anywhere. Any advice? Thanks
You do not need to replace that carb you just need either a better kit that explains things or you need to go back and set things correctly. These M/S carbs are simple to rebuild if one has the correct instructions.
I recommend the Walker Brand kits I buy for my local O'Reilly's. They have very good instructions in the kit.
If it has the rubber tipped float needle when you put it in you need to put a set in the rubber or it will leak till it has a number of hours on it.
To put a set in it you simply drop the needle into the seat and tap on it a few time. Also a leak can be cause but not putting the gasket ring under the needle seat or not gettign ti tight enough
If you kept the original all metal needle valve put that back in the carb those needle valves with the rubber or neopreme tips almost never work right for me.Also if you didn't install an inline filter between the fuel pump and the carb you're probably getting what ever the original problem was back in your new rebuild.
