CA question
TractorGreg
New User
Hello, I had a model B in the past and am now thinking about
getting another for show and a light use tractor, my question is
about the CA and it's hand clutch on the axle, if this were to
have problems could it be deleted with say a model C axle or
final drive or does the unit have to be repaired, was thinking
about the B or C for the this reason but wanted some info. on
the CA, thanks in advance for any response
Probably 90% of c ca is imilar to B so if you like the B you will not regret the C. You might not need the hand clutch unless you have a live power application like bailing. One good thing about those tractors seems to be a good supply of parts new and used like a Ford 8n.
