Allis C no fire
44 massey
I have a 1945 AC C with magneto, started up right after last run maybe 2 months ago!! I drove it around for
about 1/2 hr tractor was running perfectly, I shut it off went to start it right back up, not fire, had to leave it for approx
1 hr came back tried it again, popped right up ran perfect!!! This has happened several times, time or two tractor
died and would not start till cooled down!!! Am thinking possibly condenser or coil??? Any other ideas??
Is it electric start or hand start?? That info can help us help you but I will go with it being a electric start. Also have you done a tune up or other such thing to it in the not so distant past??
If no good chance the coil is going bad.
Ordered new coil today, took the mag off and took it apart and coil has a burnt smell and looks like it has some "melting" affect as has some black seapage from center!!! Will put new points and condenser in too!!! Thanks guys for the input!!!!!!g
