Front loader for D-19
crankymantim
New User
I have just bought a front end loader for my D-19, a "Freeman 3000." The boom cylinders have two hoses, as does the bucket cylinder. On the rear of my tractor, I have two hydro ports and matching activation levers. I am assuming that I need a supply line and return line for the loaders cylinders.
[/img]
Looks form your picture that you have only single acting hyds so they will not work as is for a loader.
The two ports you have piped in are for one cylinder,the two plugs to the far left need to have the plugs removed and quick disconnects plugged into them for the 2nd set of hoses,Both of them
are for double acting cylinders the plug to the far right is for a single acting cylinder.
Got one of the plugs out and "stripped" the hex slot on the left hand one. Got it drilled, waiting for Ag store to open today to get another "easy-out." Thank you very much for the info, sure made things a bit clearer and helped a lot!
