Drain plug removal
I am changing the rear differential and transmission oil in a model B. What tool do you guys use to remove the drain plugs? I got one out with a 3/8 socket extension but the other one is very tight and the socket extension is too small. Also what oil should I put back in?
I use UTF 303 fluid in my C which is a lot like the B. If I remember right the manual calls for 20W non-detergent oil
