Allis G stopped running
Mark Gundrum
New User
I started my Allis G and drove towards Garage and all of the sudden it just died. No spit or sputter just like someone hit the off switch. It has fuel and is getting to the carb. It won't fire for love or money. Please help!
As with any gas engine you need to do some simple trouble shooting.
#1 check that you have a good blue/white spark at the center wire of the distributor cap if it is a battery ignition and the spark has to jump a 1/4 inch gap or more. If it has a mag you need to check spark at all the spark plug wires. If it is a battery ignition and you do not have spark try a hot wire from the ignition side of the battery to the ignition side of the coil
#2 just because you have gas to the carb does not mean you have gas in the carb so you need to pull the carb drain plug and let the gas flow. It needs to fill a pint jar in under 3 minutes.
