Anyone have or use implements on Allis C CA tractor
JOCCO
Looking at a few things was wondering what you guys have or use. Need to get the manuals but was quite interested in the belly mount sickle mower, the plow, and buzz saw that mounted to back. Cultivator would be a good find too. Anyone got any photos of the above? thanks
First you have to distinguish between a C and a CA. They mount totally different. I have 2 CA's, used 2 row cultivators on them for years, also pulled 2-14's fairly easy. I think the C only has a 1 bottom plow, I am sure there is someone on here that can add more about a C than me. I also have a 3 ph on one of my CA's and pull a 6' finish mower only gives me problems going up steep hills in tall grass.
I have a C with the B/C belly sickle mower. I think the one for a CA is different then the B/C one. Up till my old computer crashed on me I had the manual for it also but when my old computer died it took my info with it
Jim; I am thinking about buying a three point hitch adapter for my ca.Have you had any problem with your top link bracket where it hooks to the tractor.or any other problems with the adapter.Hayspear has one for 410 dollars plus 105 dollars for shipping.Undecided about buying until i know about how well it would work.Thanks for any info. you can offer Barney
I like it a lot. Being a belly mount it makes it easy to keep an eye on what it is doing.
Old how is it mechanically to use and maintain does it work real good? Also what is this frame difference with the ca? Used to be a few around but they are not in use now. Thanks
To used it is like any other sickle bar mower you keep an eye on parts since they tend to work loose form vibration but that is on all of them. As for how it is different all I know is what the other guy said and he said it is longer for the CA but the CA is bit longer then the B/C is
