d 19 clutch adjustment
fwilliams
New User
3 bolts on the pressure plate, which way do you turn for a slipping clutch ? makes sense to tighten and increase pressure but thought I would ask to make sure, thanks
You turn them whichever way creates a gap between the throw out bearing and the finger tips. Probably loosen them. If there is already a gap, there is no adjustment that will fix it....time for a new clutch.
