82S Mower guards
All,
My 82S mower still has the single guards on it. Can I put newer double guards on it? If so what kind new holand, int, or john deere? The singles don't stand up in our june grass like the doubles causing it to stop. Were these bars made to handle double guards?...
I have a 82T with New Holland double guards on it.Do you have a sharp blade? And I mean sharp as in like new sections a dull blade will beat those mowers to pieces.Also the
82S will get worn some and let the cutter bar come back a little and cause it to run on a slight angle this will cause it to cut poorly.
I have a 80T mower that I've rebuilt almost from the bottom up. Used it for 1st cutting hay and it did okay. But I want to rebuild the knife/sickle and am interested in using NH double guards on it as you recommend.
However, I have no idea what specific NH part number to get for the job. Could/would you give me the necessary part number info for the NH conversion? It would be appreciated very much.
Thank you.
Get a complete sickle assembly from Webb's Sickle Service better than the original AC sickle assemblies,you'll think you have a new mower.Also get a New Holland hold down for the outer end of the cutter bar it holds the sickle end down far better than the AC one does.
