Allis C CA tool box problem
JOCCO
Any idea how to deal with the tool box the round door is missing. this is on a c ca allis can you get one anywhere? I did not want to buy a whole new one. Thanks
I would have to look to be sure but I bet I have at least one on a parts C I have out in the junk yard area
Yes old I wanted to get in touch as I may need some parts I bought the ca allis and the axle clutch is bad. Looks like box cover is available.
I have made several! I cut out a pattern from a good door and traced it on a piece of sheet metal. I cut it out with a saber saw then files the edges. I put it in a vice and bent the tab to match a good door. I spot welded it to the tool box using a hinge that looked as close to the factory as I could find.
It doesn't take that long to do. I might have had an hour in one.
I used this door to trace when I made a new tool box.
