WD 45 power steering set-up
does anyone have a complete power steering set up for sale for a WD45? It can be char lynn or a true factory set up. I want to install one on a 45 with a D17 engine. It would have to be a compete set up. Which is better anyways the char lynn or true factory?.... Thanks
They both work equally well. With the Char-Lynn you will have a chance to be able to find some repair parts. With the A/C set-up......good luck.
A few years ago I started checking into
power steering for a dune buggy. Same
thing but a lot cheaper than tractor parts.
Like I said it's been 5 or so years.
Dr. Allis, isn't the AC set up an Eaton? Dana owns
Eaton or vice versa but Eaton units aren't bad to get
parts for from Eaton but you have to custom order
most of them.
