Traction Booster Problem
Hello;
I have a hydraulic leak all the way down in the Traction Booster assembly on my 1963 D-17.
What must be done to disassemble, repair and put together again to stop it from leaking?
Appreciate the help
You're going to have to provide a picture or do a better job of describing exactly where the leak is coming from. There isn't a "Traction Booster assembly". There is a big coil spring underneath the transmission housing that makes the Traction Booster system actually work and a link rod that goes from this spring to an arm under the torque tube that signals the hydraulic pump. If the big coil spring is wet with oil, I'd be looking at a dozen loose bolts holding the tractor together at he dashboard area. The PTO lever seal could be leaking on the left side. The hand clutch thru shaft could be leaking on left or right sides.
