Allis b with woods deck, help
Dustyah
I have a 1945 allis b, with a woods l59 , recently went from 8.5x24 to 9.5 x24 tires, has to move deck farther forward one set of holes, now my old belt, worse for wear keeps rolling over pulleys, was instructed that may be due to having to lift the idler pulleys on tractor to get more room outa belt, my old part # is woods 3652, so anyone with a b with a l59 help
Dusty
If the front idler is too close to the tractor belt pulley,it does not have enough room to make the 1/2 twist. Raise the back idler pulley
and lower the front idler pulley as far as you can. BTDT
Do what Ted said first. If that doesn't work, it may be due to the belt needs to be replaced, sometimes once it starts rolling you can't stop it.
You can get any belt at www.jdv-belts.com at a better price than Woods. The Woods belt 3652 crosses to JayDee # B225K.
Bill B
(quoted from post at 06:22:26 05/29/17) Do what Ted said first. If that doesn't work, it may be due to the belt needs to be replaced, sometimes once it starts rolling you can't stop it.
Bill B
Thanks all, will do and try, but since I went to taller tire and moved deck forward, do I need longer belt??
Dusty
I went to 11/24's on my C from a smaller tire I still used the same belt. I did move the mower down at the back one hole. I don't think I did move it forward. I can't see why I would have. I still have the small tires on my B and anytime the belt turned over I could not get it to stay without rolling until I replaced the belt.
If the above suggestions do not fix it , run it with the belt turned over till it is worn out. Also note the Woods mower manual says the belt
must be very tight. It will work , I did it for two years.
