Tim in New York
Oil pan was leaking pretty badly, so I got it off, cleaned everything well, and put on a new gasket. Now it leaks horribly - way worse than before. Its leaking from the front mostly, but also a fair amount from the back. The old gasket had some silicone stuck on it. Did I miss something? The gasket did not seem to match up quite right in the front. Is there some trick to this?
If I have to use silicone, its a tight fit. Can I take off the wishbone for better access? How do I do that safely?
Thanks,
Tim
Thanks,
Tim
