khouse6
feller that is trying to remove the brake wheel, from axle, is having a problem. he has heated and pulled with 2 jaw puller. moved about 1/2 inch and no farther. he is afraid that he will break it.
he believes that a 4 jaw puller would be better.
any suggestions?
stud bolts are broken off in lower portion of axle housing. need to remove, so machine shop can drill out broken bolts.
