CA and D10 parts
The engine will fit but you go from a crankshaft stroke of 3 7/8" down to 3 1/2" which will drop the HP of the tractor.
You would have to use the flywheel and clutch from the D 10. The CA flywheel is smaller than the D 10 and the starter would not engage the ring gear. The large crankshaft ends are the same on both.
CA had a 125 ci engine. Early D10 had a 139. Also note that later (SN 3501) D10's had an even larger 149 cu in engine the same as the D14 and early D15.
