John Achmann
So I'm rebuilding this engine for my cousin. He bought the tractor with a stuck engine. When I pulled it apart I noticed everything looked like it was not that old. If it wasn't for the stuck pistons id clean everything up and reassemble. So not knowing the history of this tractor I got a new overhaul kit. In the process of cleaning the block I noticed I couldn't blow through the tee fitting on the right side center of the block. After doing some looking I'm sure the center can bearing is wrong. So here's my question, does the center camshaft bearing suppose to have two holes? I only ask because looking at photos of cam bearings on the web they only show one hole. I've even looked on this site and they only show one hole. They do state the center bearing is different but they say it's a different size. Any advise is appreciated!
