Model G Hydraulic system swap tip?
oldbart
New User
Hi there, I was wanting to swap the hydraulic set up from one G to another. I have one with a 12V system and manual tool lift, and one with a 6V system and a stock Hydraulic setup front and back. I would like the 12V tractor to have the hydraulics. Any tips or tricks? I have the manual and it looks pretty straighforward?
Not a hard job, only thing I'd recommend is going ahead and pulling the blank plate on the tractor you're moving it to
and be sure there is a hole already drilled for the suction tube to go in,it's just above and to the right of the bottom left mount hole. some early ones were not drilled. Also be sure to pull the tube out of the old tractor and put in new one! As me know I know that one!!!!
<a href="http://s33.photobucket.com/user/Joecdeere/media/allis%20g/DSaC00063.jpg.html" target="_blank">
</a>
