Re: Deleting Hand clutch from WD
It takes two of the front spline adapters . Split the tractor unbolt the hand clutch from the front spline adapter get another one it slides on the
splines wher the clutch was and bolt the two together. Remove the over center throw out assembly and put the two halves back together. You'll
need to get the other adapter from another WD. Check EBay and local dealers for old stock. You can remove the handle and linkage from the
outside but the rod that goes throught the case needs to be there to keep the oil in.
If you're cutting weight you get an elimination shaft out of one that didn't have a hand clutch. Im sure someone
makes them but I don't know who.
