Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
7040 Hydraulic Pump
gearheadbill
03-18-2017 16:58:37
Am working on a 7040 that needs a hydraulic pump, the gear pump that supplies oil for the steering, lube, and charges the piston pump. It is about $3000 through Agco and am wondering if another vendor sells these. TIA
Jr1983
03-21-2017 03:02:17
 Re: 7040 Hydraulic Pump in reply to gearheadbill, 03-18-2017 16:58:37
A and I ha one but it is special order it sells for $4731.47. No need for a call.
Wisconsin Cowman
03-18-2017 21:19:40
Agco is the the only source I know of. A&I shows the pump on there website under part# A-70271875 but shows its not a available would have to call your local A&I dealer to find out availability.
DrAllis
03-18-2017 19:51:53
I doubt very much that you'll find another supplier. That dual pump assembly was specifically built for the 7000 and 8000 series tractors and no one else. I'd be searching for one from a salvage tractor with black paint on the chassis. The black pumps ( 7010-20-45 and newer 7060-80 and all 8000 series) had a few little internal changes that made them more reliable. Even at that, I'd replace the seal between the gerotor pump and gear pump before installing any used pump to prevent an oil transfer problem. Be sure to wrap the splines on the shaft tightly with electrical tape to avoid damaging the seal with sliding it over the shaft. Loctite the seal to the housing.
Bill in IL
03-18-2017 19:07:56
Abilene machine does not list one for a 7040 but i would sure give them a call.
