Fella's, Have my Pa's lil B split for a clutch change and it has the pressure plate with the 3 groups of 2 bolts and i believe is 8 1/2 inch clutch. My question is- can I install the 9 inch clutch for a replacement as long as the pressure plate has the 3groups of 2 bolt pattern??- I noticed that some of the 9inch clutch kits have this 3group of 2bolt pattern and did not know if i could use the 9inch kit in place of the 8 1/2 inch if the bolt holes on the press plate would match up? The 8 1/2 inch clutch on the tractor now has the press plate with the "flats" on the sides instead of the "round" press plate i see included with the 9inch clutch. The one 9" i seen had a round press plate but the 3group 2bolt pattern. Hope this wasnt to confusing, Thanks so much for any help, Hoss
