3point lift not qworking on 7030 AC
Farmallb
My boy bought a 1974 7030 AC. He says the 3pt works fine AS LONG as it isn't lifting anything. Any thoughts appreciated.
You'll need to get a 3,000 psi gauge connected to the "tee" fitting on the PTO valve and do some pressure checks. Do the remotes lift anything??????? or is it just the 3 point......two different problems are possible.
