WD 45 live hydraulic pump
Sorry pic didn't attachand I was referring to the live hyd setup.
Interesting. I've never seen one. But it would be a challenge to fit one to a WD45. It must be a generic unit for any tractor with a magneto drive. Because that's what I'm seeing in the picture. WD45's had a factory distributor drive/governor assembly. I suppose you could get a magneto drive off an older tractor (WD/WC) to make this thing fit.
I've seen some very similar to that for IHC tractors. They were
made by M&W. M&W pump used the IHC distributor. The distributor in
the photo looks like a Delco.
That tractor is either a WD with WD45 decals. Or someone has put a
WD governor on 45. WD45's didn't have a flange mount distributor.
