Wc clutch replacement?
Hossman
Guys, could someone tell me if the 9 spring pressure plate and clutch from a later model wd45 fit a styled wc? Also does the pilot bearing go with this "swapout" instead of the current bushing? I have removed the original clutch to replace and thought the heavier duty one from the wd45 would be better? I was under the understanding that the clutches were interchangeable but have been unable to confirm this. Thanks for any help, Sincerely, Hoss
You would probably have to swap flywheels to get the pilot bearing. Easy enough to do. The cranks are the same so it's a bolt in swap.
AaronSEIA
