Model B PTO
Ted in NE-OH
On the model B PTO there are some metal shims that use paper in between them.The thin paper shims are no longer available so what do you use. I know from experience that in you don't use something , it will leak oil. The thinnest gasket material I can found is .032" . Should I use gasket cement in place of the paper or what.
You can use actual paper, like printer/copier paper, or the cardboard
(white newsback in paper company terms) from a cereal box if it needs to be thicker.
