FR10B Fiat Allis Loader
Skyhook
New User
My loader was running fine when it was park> It set about a month and when i went to start it back up it only idles and will not speed up. I change fuel filters and fuel shut off solenoid but still the same. I unhook fuel return line coming back to tank but no fuel is coming out. Any ideas?
One of several possibilities... the pick up line in the tank is blocked or the primary fuel pump is not working. If the pick up line has a crack or any fitting coming from the tank to
the primary pump allowing air into the system your engine will not get fuel.
