The original gas cap on this D17 was hard to remove, and was worn, and not likely sealing well. I bought a brand new cap (Made for the D17) at my ACCO dealer. The new on is even harder to remove. I have to use a large Channel-lock to remove it, and to tighten it well, too. Nothing appears deformed, bent, or otherwise abnormal on the hole in the tank.
Is this a common problem on this tractor model?
Is there something that can be done, or applied (such as grease), which will make it easier to turn?
This is not the worst problem in the world, but when I ran out of gas, a mile from home, in zero degree weather, had a can of gas, but could not get the cap off, (and did not have a channel-lock handy), it WAS a big issue!
Any tips or suggestions?
Thanks
Thanks
