allis b and implements
echo_cons
going through craigslist under Milwaukee, wi. saw 3 allis b's with a bunch of implements for 2300 bucks one tractor looks like its in pretty good shape. more of a red fan, but looked like a pretty good deal to me (I could be wrong though) there down in the Kenosha area
Bs are a good tractor, basic and simple to use and work on. With ACs of that era you need to watch the boot on the shift lever, if it is cracked or gone water can get
into the transmission if they are left out in the weather. You might want to pull the drain plugs and see if any water. At least look at the color of the oil after
running them for a while if they run.
Depending on what all is with it $2300 is a tad bit high. Where I am you can buy a B for under $1500 and many times that is with some equipment
