8050 fwa oil pan
cjrpr
Probably a dumb question because I think I
know the answer by looking at it. Can the
oil pan on a 8050 be removed with out
removing the fwa axel?going to overhaul the
engine.
Remove drive shaft and roll front axle forward and let frame back down on top of it for in-frame OH.
dr allis - not sure what you mean. do you have to unbolt frame attaching bolts to italian 4 wd axle. get it to move forward a little and then drop pan ? thank you
Unbolt the framework/cradle the FWA axle is attached to. I think maybe 8 bolts to the side frames from underneath. Roll the whole thing forward and let it back down. Unhook drive shaft and steering hoses.
