d14 power director
DGK
seems to work sometimes hot or cold cant find filter, is there a screen somewhere? any ideas
When you say its not working do you mean it won't and make the tractor move or that it won't release and let the tractor stop? Also does it do the same in high and low range?
Its forward reverse shuttle, works good then tractor wont backup,give it a little bit and it will work again. oil is full but hasn't been changed in years. thanks for looking
Moving the shuttle lever forward and backwards squeezes the clutch discs together. If it only bothers on one clutch, it may need shims removed to compensate for wear. The "snap" should be the same between forward and reverse. If it bothers in both, the foot clutch may be slipping. Is there any freeplay on the clutch pedal ??
