hydraulic problems D-19
NEKS
When I raise the lift arms and take the lever back to hold they creep down and pretty fast. Probably a valve seat leaking by. What do I have to do to fix it and can I get parts.
There is a check ball in the valve stack that goes bad along with the seat that causes that. If you go to AGCO parts books online there is a break down in the parts manual. If you need further help locating and fixing it I recommend a service manual.
