AC 200 Tachometer Cable
Having trouble getting a tachometer cable to last more than a few hundred hours in an AC200. This is the one that goes from the alternator to the tachometer. Any suggestions would be appreciated.
Thanks
Check and see if the tachometer is turning hard. They can get sticky and turn a little harder and that will soon break the cables. You can also lube the cable inside the liner. You use powered graphite not oil.
