C Allis Chalmers Pistons
Buster
Putting a sleeve kit in a C and have a question. Pistons have a small notch on top, does this go towards the front or rear? Old Pistons had the notch on the bottom but they were facing different directions. Does this matter which way they are installed?
Choose right or left or even mix them front or back. On the C engine it will make mo difference. I personally would make them all go the same direction which you would have to put two one way and two the other way when installing the rods. I have not bought any marked pistons for an Allis C type engine. Normally it marks oil holes under the rings for slant cylinder walls.
