It all depends on which coil you buy. Some coils tha tare called 12 volt need an external resister and some do not. The key is to buy a coil that says right on it no external resister needed.
If its a full true 12 Volt Coil on a 12 volt tractor NO external ballast is required
A coil labeled "12 Volts" or "12 Volts not for use with ballast" is a full 12 volt coil NO ballast required just as it says
HOWEVER a coil labeled "12 volts for use with (or requires) external ballast" is more in reality a 6 volt coil and needs the ballast just like it says.
John T
