Tim in New York
Got the pump off the tractor and in the vice, but cannot get the pulley off the shaft. I did tap the pulley gently with a wood block and drove it to the end of the shaft - it is loose and wobbles around, but does not want to come off the shaft. Do I just need to drive it off the shaft with force, or is there something holding it on that I need to handle differently? I don't want to bust up something by being careless.
Thank you for your advice so far on this project - I'm almost there.
Tim
Tim
