Jason Yochum
New User
I recently purchased my first AC and it's a 1952 B. I has a homemade 3-point on it that was made by one of the previous owners. Attached is a picture showing it but basically, they mounted some flat plates to the final drive housing and welded a piece of angle iron between with some pins to mount the lower arms. The pump had some problems and the aftermarket cylinder that was on it lifted but leaked really bad (bad enough to have a return line going back to the trans). My question is will one B cylinder be enough to lift my blade with this setup? I have thought about welding two more brackets onto the left side of the rocker shaft to accommodate two cylinders but I would rather skip this and go with one if possible. Thanks in advance for any input. I can take some better pics if needed.
