Allis Chalmers 170 Gas
slifnom
I am wondering if there is an adjustment on this tractor for the steering! I was at road speed and it seemed to wander a lot. It has power steeringThanks in advance
There is no adjustment. The steering system joints must all be tight....tie rods, steering arms on top of each spindle, etc. The swing arm in the middle is probably loose on the splines of the steering shaft. The toe-in on the wide front must be 1/4" at the centerline of the front tire. Finally, the steering hydraulic cylinder may have internal leakage, allowing oil to bypass. Take care of the external things first, and then reseal the steering cylinder.
