Tim in New York
Got the radiator and fan off and started on the pump. It looks like the pulley needs to slide forward in the two grooves, so that the pump bolts will clear the back of the pulley and come out? I got the two small nuts loose in the grooves, but cannot get the pulley to move forward. Sprayed the heck out of it with blaster - its has not been apart in a long time, if ever. Any tricks to getting the pulley to move forward?
Thanks - I know I need to buy a shop manual - will order one when I order the pump, belt, and thermostat.
Tim
Tim
