6070 steering
Doug Wi
Neighbor has a 6070 mfwd. He says when you start it the steering turns to the left w/o touching the steering wheel. Seems to work ok after that. Leak somewhere the steering circuit?
I'd be suspicious of the centering springs in the orbitrol getting weak and favoring the left turn. If it isn't causing a problem, why worry. If it is, I'd replace the centering springs. Not a job for a novice.
