Help identifying
Jasont22
New User
Was wondering if someone could help me figure out what model this is. The serial number starts with 160 but when I researched it i found wd45 but from pictures I have seen it doesn't look like most of them and on the motor it says power crater or something like that. I thought it looked more like a d15 but I don't know a lot about these tractors. If anyone could help I would appreciate it thanks
You are probably looking at the engine number if it is a gas motor. The 160 cid engine was used in the I60 and I600. The tractor serial number should be on the torque tube next to the engine number, which is on the engine flange.
Looks like my I600,yours must be an I60 or you're looking at the engine serial number and its a 160 engine.The serial number for the tractor is on the bell housing not the engine
Thanks for all the help I was thinking that was the serial number I will check and see if I can find it where yall had said. I had bought the tractor
really cheap and I am in the process of rebuilding the motor and wanted to make sure I buy the right parts. Thanks again
(quoted from post at 03:20:25 09/08/16) Thanks for all the help I was thinking that was the serial number I will check and see if I can find it where yall had said. I had bought the tractor
Be very careful with the piston connecting rods....they are made of gold!
