AC7000 3pt TB lever positions (Maroon belly)
Farmer AK
Would someone tell me the correct "Traction Booster" and "Position Control" lever positions for these two handles/levers to be placed in when I don't need the TB function and just want to use the 3pt to raise and lower an implement like a brush hog or similar item that does not require the TB action? I have read the operators manual, but somehow it isn't coming across to me where they should be set. Any other info that might be helpful with the use of the 3pt would also be appreciated. Thanks.
Both levers clear forward will allow the hitch to fully lower. Use the longest front hyd lever to then raise-hold-lower the hitch.
Dr. Allis: Thank you for the response and instructions for setting the levers. I'll give it a try this weekend. Thanks again! Farmer AK
