I posted a bit back about this backhoe. It has a 239 CID cummins diesel. I was having trouble getting it to run right. It would start and run for 15 seconds and die. Then after cranking some more I might get it running. It does not run right. This happened all of a sudden. I changed the fuel filters and the same thing. So yesterday I was looking at the injector pump, and as some suggested here, there looked to be a big fitting on the fuel input line. I pulled it apart and sure enough there was a screen in the line. It was really clogged. I cleaned it all up and put it back together thinking I got it now. Bled the system and got it running but the same thing, no power, ran for a bit and stalled again. Like I did nothing. I'm getting frustrated, is it new injector time?
