well i had a bad experience the other day,while driving my wd45 home from on blacktop road ,i noticed tractor
not responding to steering wheel. i put in clutch and brakes at same time and came to stop. when i got off
tractor to see what happened, I discovered that the pin that connects the power steering unit to the drive
collumn had come out.I made it home by using a 3/8 bolt for pin. can I fix this by using a #8 hard steel bolt
with locknut plus drill and cotterpin thru nut and bolt.
