D-19 lift arms
NEKS
The valve for the lift arms will not hold it up. How much trouble is it to tear into to fix? And what parts do I need? Thanks
(quoted from post at 11:34:18 08/27/16) The valve for the lift arms will not hold it up. How much trouble is it to tear into to fix? And what parts do I need? Thanks
Probably the spring and check ball just needs replacing. Google SandyLakeEquipment, call and ask for Brenda, she will get you what you need. Then you just have to take the bolts out that hold the valve stack together and replace...might have to seat the ball.
